08-11-2005 08:58 PM
08-11-2005 09:07 PM
Hi
I have this unfortunate situation as you did. I actually have LV 7.1, LV7.0 and LV6.1 all on my pc. just remember that the VI will be opened with whichever version was last used if you click on it. so if you accidentally opened a VI intended to run on ver 6.1 for example with ver 7.1 and saved it, you will not be able to open it with 6.1 again.
Goy
08-12-2005 01:36 AM
There is definitely no problem with having multiple versions on the same computer, and I can't say I see any reason why installing an older version would mess things up (although I do seem to remember seeing something along those lines recently. Try to search for it).
One point - 98 supports 7.0. Any reason not to build the app in 7.0?
08-12-2005 01:50 PM
08-12-2005 02:27 PM
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.08-12-2005 02:27 PM
Matt,
I would suggest installing it in a National Instruments1 or National Instrument_6.1 directory instead of the National Instruments directory. I have done this in the past and had 3 versions on the same machine. Hope this helps.
08-13-2005 10:10 AM
