Install LV2010 on ubuntu
I try to use the command 'sudo sh INSTALL' to install LV2010 on the latest ver of ubuntu, but it gives error in the process as attached.
Any suggestion, thanks.
Message 1 of 13
(4,196 Views)
Hi Alex,
I'm not very familiar with linux but this seems to me like a typical file permission problem.
You could try change the permission of the installer using chmod.
Hope this helps,
Christian
Message 2 of 13
(4,185 Views)
May I know how to use the chmod.
It is said ubuntu only support .deb install file, but the ones on CD is .rpm.
Message 3 of 13
(4,178 Views)
man chmod
Message 4 of 13
(4,136 Views)
It should not work with ubuntu. .rpm is generally for fedora or suse distributions.
Message 5 of 13
(4,116 Views)
There is a package called "alien" which allows deb based distros to install rpm-based packages.
Search on the Internet for how to use it.
I'm not saying it'll work straight away, but others have had the same problem and have managed to get it working.  Don't have any links though, sorry.
Shane.
Message 6 of 13
(4,094 Views)
I have had it successfully install before but i cant remember if i used alien or just ran the ./install script.  However someone in this thread has got it running on ubuntu 64.  You may not run into the 32/64 bit library issue but if you do the solution is in this thread also.
http://forums.ni.com/ni/board/message?board.id=170&message.id=488880&query.id=5983552#M488880
Also make sure you use the "./" in front of the install command like so.
sudo ./install
Craig
Message Edited by craigc on 01--06-2010 03:51 PM
LabVIEW 2012
Message 7 of 13
(4,054 Views)
Wait a minute... LV2010 is out?
Richard
Message 8 of 13
(4,041 Views)
It's not. ALL discussions regarding the beta are supposed to take place in the beta forum. I'm surprised Christian discussed this on an open forum.
Message 9 of 13
(4,019 Views)
Ooops and i have only just noticed the 2010 part. sorry!
LabVIEW 2012
Message 10 of 13
(4,009 Views)
