Install LabVIEW 2013 on Scientific Linux 6.4
Has anyone successfully installed on SL6.4? I install and no response - try to start using icon but no errors or slash screens. Did put the 32 libc2 on the machine. It asked for kernel sources, but for 64 bit?. What is correct?
(3,080 Views)
Zander,
I have not installed LabVIEW 2013 on Scientific Linux 6.4 before, but I will see if I can help you out. First did you install LabVIEW 2013 32 bit or 64 bit? Second does just the LabVIEW shortcut on the desktop not work (icon) or can you just not load LabVIEW at all?
(3,019 Views)
I was successful. I was trying to install on 64 bit SL64 (x86_64), using compatibity libs, got stuck on nvidia drivers. Downloaded SL64 32 bit (i686) and it went flawlessly.
(3,000 Views)
