Install National Instruments device drivers.
I am working on a project using LabView.
I installed it few months ago and it installed normally.
After that, I had to uninstall it.
Now when I reinstalled it again, it gives a message about installing NI drivers.
I am attaching a screenhot.
labVIEW is asking for additional drivers for it's installation.This did not happen before.
Please Help.
Message 1 of 9
(5,773 Views)
Install the drivers.
Message 2 of 9
(5,760 Views)
I would not have asked this question then.
It asks for "additional drivers" (clearly written in the question).
I already installed the drivers I had. Do you have something useful to offer?
Message 3 of 9
(5,755 Views)
Check in your project, are you using DAQmx drivers or not. If not you dont need to install any.
Message 4 of 9
(5,743 Views)
But you uninstalled LabVIEW. Drivers have to be installed after LabVIEW is installed if you want to use them.
Message 5 of 9
(5,740 Views)
I uninstalled it few months ago.
Now I have reinstalled everything again(including the drivers)
Message 6 of 9
(5,732 Views)
You said you got the message during the reinstall. Are you doing another install? I don't understand what you are doing. Getting a prompt for the device drivers is perfectly normal when you install LabVIEW.
Message 7 of 9
(5,726 Views)
When installing LabVIEW, you need to install the drivers.  If the drivers are already installed, then you still need to install the "LabVIEW 2010 Support" for the drivers (part of the driver installation).  This is quite normal.
Message 8 of 9
(5,690 Views)
Have your problem solved ? i have the same problem exactly like you also. Please help me thanks !
Message 9 of 9
(5,105 Views)
