Install directory
When I create my application installer I want to install into a specific directory and don't want the user to be able to change the install directory - is this possible and how.
Thanks Wayne
(3,279 Views)
This is not possible with the LabVIEW built installer.
(3,278 Views)
It's true that this feature is unsupported, but if you want, you should be able to go into the setup.ini file, and disable that dialog window, and the user won't be able to change it.
Nick D.
**Note** I know this post is from 2004, but I just wanted to update this forum incase other people stumble upon it.
Message Edited by Nick D on 09-17-2007 01:32 PM
(3,085 Views)
