Install labview 6.1 (or compatible) run-time engine with labview 2011
I have installed a trial period version of Labveiw 2011 in order to check for possible upgrade issues I may have if I decide to upgrade from labveiw 6.1. Well, needless to say there have been alot. That is as expected since I have not updated labview in many years. I am still not under any pressure to update; however, I would like to in order to get support and make sure I do not have any compatibility issues with new  equipment purchases. I have been able to resolve most of my compatibility issues with simple code fixes and such. However, twice now I have run into an error when launching labview executeables compiled by two different equipment manufacturers. The equipment I am using is not even old...maybe a year or so. When I launch the labview executables to control this equipment on a PC that has the trial period labview 2011 installed, I get an error message stating something like " This requires a Labview 6.1 (or compatible) run time engine." I have tried to download and install the 6.1 labivew engine but I can't install this engine on a PC which has labview 2011 installed. Can someone explain how I am to run these executables under labview 2011. I can't imagine these executables were developed using 6.1 since this equipment is not even a year old now.
(6,153 Views)
Are you running Windows 7?  Does your "legacy" code run on Windows XP?  This is "answering a different question", but if you wish to use Windows 7, you will not be able to develop code with LabVIEW 6.  Indeed, versions before 2009 are not supported on Windows 7 (though if you try real hard, you can install LabVIEW 8.6, I think).
(6,145 Views)
Im not for sure I am on the same page with you here. Im not trying to develop any code myself. I have some labview executables that came with hardware we purchased in order to control it. We used to have labview 6.1 installed; so everything was working ok. But now that I have installed 2011, I get an error message when trying to run these executables. The error message states that this executable requires a labview 6.1 or compatible run-time engine. I have seen this error on both XP and Windows 7 machines. I did not develop the executable, it was developed by the hardware manufacturer. But since this hardware is only about 1 year old, I an assuming they used a newer version of Labview to develop this code. Certianly newer than 6.1.
So I guess my question is..is there a way for me to get this executable to work on a PC that has labview 2011 installed. I have tried to install a labview 6.1 run time engine but it will not install. Any other options?
(6,134 Views)
First, what exactly happens when you try the install? Second, check with the vendor about which version they used. Don't assume they used a newer version.
(6,126 Views)
well i checked the manufactures website for updated downloads. And my assumptions were incorrect. Apparetnly, it states that labview 6.1 is required to run the executable in question. So, I guess we will not be updating labview since this executable is required to run needed equipment.
(6,113 Views)
Accepted by topic author labview_user_1234
You should be able to have any number of run-times installed and 2011. I have multiple versions going back to 7.0. I asked what exactly happens when you try the install.
Have you tried removing 2011, installing the 6.1 run-time, and then installing 2011?
(6,110 Views)
Dennis.....you are correct. I was able to install both 6.0 and 6.1 run time engines and use the executables. I had tried this earlier and it would not install. Maybe I had downloaded the wrong thing from NI previoiusly... i'm not sure. But today, I downloaded both of these run time engines and they installed without any issues. Thank you.
(6,096 Views)
