Install labview runtime engine in microXP?
Hi folks,
As the title says, did anybody try to install? I am getting error without any code in microxp 0.82.
Thanks in advance.
(3,482 Views)
I didn't know about microXP until I saw your post 😮
I'm not supprised that it doesn't work... If you remove parts of Windows it's kind of expectable to not be able to use any software you want.
What would be interesting though is the list of things that are required for LV to work on Windows, then you'd know what you need to add on your microXP. But I doubt NI engineers will take the time to do that for you.
Have you tried Windows LSD? LabVIEW was running fine on it.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,461 Views)
Thanks TiTou didn't know about LSD, very small info about it in google. I actually meant to ask for runtime engine's dependencies in my first post.
(3,457 Views)
Hi Grasho,
Thanks for your post. Unfortunately, we are only able to support the RTE for a standard Windows XP Distribution. While I don't know exactly what MicroXP omits to create it's "lite" profile, it is an unofficial modification to the OS which the RTE installer was not designed to work with.
I'm sorry I'm unable to be of further help on this occasion.
Kind Regards,
(3,432 Views)
