Install two .exe at the same installer?
Hello!
I've created an Installer of my Labview application. I want that, after the installation, install a driver (another .exe file).
I've activated the option "Run executable at end of installation" on the Advanced Properties of the Installer (see attached picture) but when the Installer finish to install my application and try to install the driver it appears an error that says: "Another installer or unistaller is running. Finish that installer or uninstaller and try again". However, the installation of my application finishes well.
Do you know a solution or other way to install a second .exe?
Thank you!
Message 1 of 9
(4,303 Views)
If they're both LV programs, just create 2 exe-builders in the project and install them both in the installer.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 9
(4,274 Views)
Thanks for the answer but, one of them is a LV program but the other one is a setup.exe downloaded from internet which I would want to include in the installer.
What could I do?
Message 3 of 9
(4,264 Views)
Add the EXE to your project.  Then under the build epecification of the EXE add it to the Always Include section.  Then make the installer using the previous build.  It will now bring along the LabVIEW EXE you made, and the one you specified in the support folder.  If you want this EXE to be ran during the install this can be selected in the installer build specifications.
Message 4 of 9
(4,258 Views)
I've done what you say but I'm unable to find in the installer build specification how to select the setup.exe so that it can be run during the install.
I've attached a picture if you want to see my project files tree and where are the two exe's.
Thanks for the support.
Message 5 of 9
(4,245 Views)
I don't have a computer I can test it on but I believe there is a post install action under the advanced section where you can run an exe or batch file. Here you should be able to select your other exe.
Message 6 of 9
(4,227 Views)
It's what I do (as I tell on the first post) but when the Installer finishes to install my application (Install finish.png) and it try to install the setup.exe (Install error.png), appears an error that says: "Another installer or unistaller is running. Finish that installer or uninstaller and try again".
Any ideas?
Message 7 of 9
(4,213 Views)
Any ideas?
I'm so sorry that I didn't read your first post more closely.  The error you are getting is likely because only one instance of an NI installer can be running at the same time.  One installer can't cause another to be installed.
One suggestion I do have is you can create your own installer, not including the second installer.  Then make a Inno Setup installer, that installs each of them one at a time, and you can use slilent switches so the user only has to tell it to install once.  Inno Setup installers aren't complicated but to make it a little easier I use ISTool which makes life a little easier with a GUI.
Message 8 of 9
(4,198 Views)
Thanks. I'll try this.
Message 9 of 9
(4,124 Views)
