Installation NI CompactRIO-9030
Thank you.
I attached VI.
Message 11 of 22
(2,158 Views)
Hi Asgar,
use TDMS file functions when you want to save a TDMS file!
What did you try so far?
Message 12 of 22
(2,154 Views)
Thanks. I am not in that step. I have created a new RT project and after compiler FPGA vi it works and I can run the host VI which can see the plot of data but I don't know how to save this data after showing in the plot. Smiley Mad
thanks
Message 13 of 22
(2,151 Views)
Hi Asgar,
I repeat again: use file functions to save data to files!
As you asked for TDMS files: use TDMS file functions!
When you don't know how to use them: study the examples coming with LabVIEW!
Which of these steps do you have problems with?
Message 14 of 22
(2,147 Views)
Thank you. I have error 61072 based on the attached files. I am using the hard driver memory for save the data, I think this error related to memory, is this true?Smiley Surprised
thanks
Message 15 of 22
(2,128 Views)
Hi Asgar,
The error message is quite clear: don't fiddle with FIFO length!
Define the FIFO length once in the FPGA part of the project, then don't even try to change it dynamically later on! (Not unless you are REALLY sure what you are doing then!)
How is this error related to your problem of trying to write a data file?
Message 16 of 22
(2,124 Views)
Thank you. I am trying to get data from the waveform graph but I don't know how to do that. You said before that RIO doesn't have access to your PC's hard drive. It can only save files on its own drive! by then, I don't have SD card in my cRIO 9030, where the file should be saved? I can see the data in DIAdem View.
thanks
Message 17 of 22
(2,119 Views)
Hi Asgar,
THINK DATAFLOW: you want to save the data that is also plotted in the graph. Even these small semantic differences are important when you program this in LabVIEW!
Use file functions to save data to files! Did you examine the example VIs coming with LabVIEW?
The cRIO has it's own internal storage - or where do you think is the cRIO OS and your program stored? Usually cRIOs have a C: drive internally…
I don't know that "DIAdem View" tool, so how did you get the data from your cRIO to your PC running DIAdemView?
Message 18 of 22
(2,110 Views)
Thank you.
Not yet!
Maybe drive C
File attached.
Message 19 of 22
(2,106 Views)
Hi Asgar,
Not yet!
Well, this should be one of the first steps when trying to learn new things in LabVIEW.
You want to learn those things, don't you?
File attached.
So you used a feature only available in the LabVIEW IDE, but not programmatically. Once your cRIO runs headless (what it is made for!) you will not even see the frontpanel of your VI!
Learn how to use file functions. Learn how to setup cRIO projects. Learn how to transfer data from cRIO RT to Win-PC. All those things are explained in example VIs, LabVIEW help, example projects, AppNotes on NIs website…
Message 20 of 22
(2,101 Views)
