Installation error: Labview 11/2011 RT deployment
I am trying to install Labview RT 11 to my PXIe-8133 controller.
I go to MAX 5.0, add/remove software to my controller, and select Labview RT 11 only (and all automatic dependencies).  When I do this, installation proceeds fine, the PXI controller reboots and shows the Labview RT status screen with 8 cores and cpu usage, etc.
When I go to MAX 5.0, add remove software to my controller, and select Labview RT 11 and DAQmx 9.35 (and all automatic dependencies), the installation fails with this error message:
NI-Generic-DesktopPC-xxxxxxxx (192.168.1.21): The specified file was not found.
Local file: C:\Program Files\National Instruments\RT Images\NI-DAQmx\nilesrInstall.ocm
Remote file: /ni-rt/system/nilesra.ocm
When I browse to C:\program files\national instruments\rt images\NI-DAQmx, I do not see nilesrInstall.ocm
I rechecked my installation options from the NI Driver CD, and it seems like I got everything that seems relevant.  What are the prerequisites to install this feature?  Do I need something from the extended development suite or something?
(3,057 Views)
Accepted by topic author gregoryng
Hi there,
I would perform a repair of your DAQmx drivers by following along with How Do I Uninstall or Repair National Instruments Software?
This should replace any files that you are missing.
If this does not work please let us know.
Scott A
SSP Product Manager
(3,037 Views)
Thanks -- this appears to have worked for me.
(3,025 Views)
