Installation error w/ VC2008MSMSs x86/x64
I built software using LabVIEW 2010 in Windows 7 Pro, 32-bit.  My customer is running Windows 7 64-bit.  On attempting to install my software, he gets the following errors:
The "NI VC2008MSMs x64" installation has failed with the following error:  Error 1935.  An error occurred during the installation of assembly component {53EF73B0-18B5-32DE-B765-B5F7FSD69550}, HRESULT: 0x80070BC9.  Continue?
This error pops up a couple of times related to different assembly components, and it also complains about the "NI VC2008MSMs x86" installation.  Any ideas?
Thanks!
(11,927 Views)
Same problem here with Windows 7 x64.  The component that's being installed only seems suitable for x86 ... should I be installing different versions?
(11,506 Views)
Hi mikejt4
Try following the steps recommended from this Microsoft knowledge base article:
http://answers.microsoft.com/en-us/windows/forum/windows_vista-windows_programs/error-code-1935/ac31...
Make sure to run the installer as or with admin priviledges
Luis S
Application Engineer
(11,481 Views)
