Installation problems with Order Analysis Toolset
I am trying to install Order Analysis Toolset version 2.0 on my computer, but it is not allowing me.  Whenever I prompt the installation, an error message appears which says "You must install LavVIEW 6.1 or higher version before running Order Analysis Toolset 2.0 Setup."  I have LabVIEW 2010 already installed.  Why is it giving me this message?
(2,462 Views)
Version 2.0 of the Order Analysis Toolset was released in 2003. NI does its best to maintain compatibility, but over the years compatibility with version 2.0 was likely dropped in favor of newer tools. In this case, the order analysis functions were incorporated into Sound and Vibration Measurement Suite starting with Version 5.0. If you'd like to use these functions, I'd recommend using the appropriate version of the suite for your version of LabVIEW.
https://www.ni.com/en-us/shop/product/labview-sound-and-vibration-toolkit.html
Luke B.
(2,437 Views)
