Installation problems
I installed the FPGA Module for LabVIEW 2013. However, I am not able to create an FPGA Project from the project wizard when I start LabVIEW. Also while installing LabVIEW, I got an error saying that it could not find the files hardware driver support. I said ok and completed the install. I then installed RIO drivers. What other device drivers and/or tools am I supposed to install in order for the "Create FPGA Project" to show up in the Create Projeect Wizard?
Thanks.
(2,574 Views)
Hey,
could you be missing the Real Time Module?
What kind of project are you trying to create? Can you create a new (empty) project and add an FPGA as a target?
Try to repair your installation by going to the control panel, select National Instruments Software, click on uninstall/change. Then repair installation of the FPGA Module.
Kind regards, Roman
(2,526 Views)
