Installed Labview software and NI USB 6008 driver, DAQ Assistant not appearing in the block diagram
Installed Labview software 8.5.1 including all drivers and NI USB 6008 driver, But DAQ Assistant not appearing in the block diagram.
Need urgent attention
(5,393 Views)
Do you even have the DAQmx palette under the Measurements I/O Palette? A screenshoot would be nice.
Christian
(5,383 Views)
What version of DAQmx did you install? Labview 8.5.1 is compatible with versions up to DAQmx 9.3
Did you install the driver after installing labview. Otherwise you won't get the VIs in the palette.
Did you try restarting Labview? This is required to reload the palettes after driver installation.
More information is required to do any further troubleshooting, as Christian says.
Ian S
Applications Engineer CLA
National Instruments UK&Ireland
(5,373 Views)
Do you solved? Because I have the same issue, could you tell me please how'd you done?
(4,629 Views)
Are you using LabVIEW version 8.5.1?
If yes, then you need to install DAQmx version 9.3. That is the latest version that works with 8.5.1
http://www.ni.com/download/ni-daqmx-9.3/2337/en/
If no, then this thread is not related to your problem, and you need to make a new thread.
(4,610 Views)
