Installer Build Error
I am rebuilding an existing Labview application (originally done in LV8.6) using LabVIEW 2011. The application works in LV2011 as stand alone but when I try to build the installer, I get the error for which the details are in the attached text file.
Please help figure out the issue.
Jeet
(2,995 Views)
Accepted by topic author jeet
The issue with installer build is fixed. It wasn't able to read the drivers from the CD drive because the CD drive had gone bad.
We replaced the CD drive and it started working.
(2,981 Views)
