Installer Problem
I have two programs I compiled with the Create Installer option.  I ran the setup for A and it ran fine.  I ran the setup for B and it asked me if I wanted to uninstall A.  It does this on several different computers and it does it if you reverse the order ie install B then A.  If you do uninstall the first program then the second install ok.  This seems like a registry problem?
Help,
Bill F
(3,003 Views)
You need to make sure that each program has a different product code defined in the installer setup.
For more details, see this application note [broken link removed; article no longer available]. Good luck!
(2,997 Views)
Ahh yes.  I did create the second build file by changing the first and doing a Save As...
Bill F
(2,988 Views)
