Installer build was unsuccessful, error code -21
I have just converted to windows 7 using labview 2012 and am trying to build an application installer.  The application builds without error but the installer ha the following error:
It appears that the installer has a problem adding the xlsx file to the install directory but the file does exist and used to work when building under 8.6.
CDK_Item_OnDoProperties.vi.ProxyCaller >> CDK_Item_OnDoProperties.vi >> AB_UI_FRAMEWORK.vi >> AB_UI_Frmwk_Installer.lvclass:Build.vi >> Installer.lvclass:Build_from_Wizard.vi >> IB_MSI.lvclass:Build.vi >> IB_MSI.lvclass:Engine_BuildDevPart.vi >> CDK_Engine_AddFiles.vi >> NI_MDF.lvlib:MDFBuildDevPart_AddFile.vi
C:\Users\e020181\Documents\My Files\MC2\MCC Source\Docs\CAN Messages TR12
Loading product deployment information
Adding files to installer
*** Error: An internal tool or library returned an error. (Error code -21)
Error adding file: CAN_for_DAS 10-07-11 with DSP DER 111026.xlsx
*** Error Details:
Error in MDF API function: _MDFBuildDevPart_AddFile
nmdkAddFile returned error code 26047
*** End Error Report
Validating...
Copying files...
Scanning files...
Updating files...
Build complete successfully.
Done adding files
(4,653 Views)
In this case, the error means that the LabVIEW distribution builder cannot find the file. For instance, in the previous post, the file "DSP DER 111026.xlsx" cannot be found. You can verify the file is not found by looking at the Files tab in the Edit Installer dialog. The files that cannot be found will appear red.
In order to correct this error, exit the Edit Installer dialog, and place the missing files in the correct directory or add the files in their current location to the project.
KwokHow
AE NI Singapore
Applications Engineer | National Instruments
Singapore (65) 6226 5886 | Malaysia (60) 3 7948 2000 | Thailand (66) 2 298 4800
Philippines (63) 2 659 1722 | Vietnam (84) 28 3911 3150 | Indonesia (62) 21 2783 2355
(4,634 Views)
I feel sheepish.  I had the file open in excel while trying to include in the build.  Thanks for your help.
(4,626 Views)
I have the problem with installer, when I had installed a new toolkit or update anything, after it I cannot build an installer. I have activated all my product again, repair labview, the previous time I had to uninstall all products of NI and install again, but I cant do it all the time.
the error message is
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
CDK_Item_OnDoProperties.vi.ProxyCaller >> CDK_Item_OnDoProperties.vi >> AB_UI_FRAMEWORK.vi >> AB_UI_Frmwk_Installer.lvclass:Build.vi >> Installer.lvclass:Build_from_Wizard.vi >> IB_MSI.lvclass:Build.vi >> IB_MSI.lvclass:Engine_BuildDevPart.vi >> NI_MDF.lvlib:MDFBuildDevPart_SetUpgradeInfo.vi
{C0A8913D-B4C4-4A41-BED1-8F0522D8048C}
*** Error: Additional error occurred while reporting an error!
*** Error Details:
Error in MDF API function: _MDFCommon_Close
MetaToolbox: Error in MetaToolbox::StrictPath::StrictPath function
MetaToolbox: Error in MetaToolbox::StrictPath::IsAbsolute function
UBRunProductBuilder returned error code -1
*** Error Details:
Error in MDF API function: _MDFBuildDevPart_SetUpgradeInfo
nmdkGetMMLangID returned error code 26262
(4,566 Views)
Hi Manushak,
So by posting this problem on an older thread you are not going to get as much traffic as if you posted on a new thread, so I advise you to make a new thread for this issue.
Peter T
(4,549 Views)
