Installer corrupts on with no D drive
I have created an installer for my LabVIEW application.
Most computers at my work has 😧 drive as hdd-partition reserved for installed programs.
For this reason, I decided to use D:\ in my installer default installation directory (see attachment).
However, there are some computer which use letter 😧 for DVD, CD device.
In such a case, my installer corrupts with the message in attachment.
I dont want to change the default directory out of 😧 drive (because it is more convenient in most cases) and i dont want to create two separate installers, one for C: drive and one for 😧 drive.
Is there any way how to resolve my problem? For example if there is no valid 😧 drive on the computer, then the installer will reset the default installation directory to C:\Program Files without crash.
Any help would be greatly appreciated.
Martin Vlček
(3,575 Views)
You should be using a path that has the [Program Files] token in it rather than hardcoding the path.
(3,536 Views)
Thank You very much for reply.
However, this doesnt solve my problem.
There is Program Files folder placed on the same location C:\Program Files on both types of PCs- regardless if there is some 😧 partition or not.
We use in our factory convention, that the special programs used at work should be installed on 😧 drive, if there is some.
Martin Vlček
(3,516 Views)
Probably the easiest thing to do is configure your development PC to be the same as your target PC.  Move your CD/DVD drive to another drive letter and map a network drive to "D:".  I'm not sure if redirects work well with installers.
Bill
CLD
(Mid-Level minion.)
(3,500 Views)
That's a good idea Bill.
Actually, for a machine that only has a single harddrive (c:), you should be able to map (d:) to it as well.  I haven't done it in a very long time, but I think you can map multiple letters to the same physical drive.
(3,485 Views)
Wow, I never thought of that.  If you dont hear from me in about a month, it's because I had to reformat my hard drive.  😉
edit: nope, not gonna try it.
Bill
CLD
(Mid-Level minion.)
(3,472 Views)
I seem to recall something about installers not liking a drive created with the subst command.  It might be if you try to install FROM one, like faking a CD drive.  Maybe you can still get away with installing TO a drive created with subst.
Bill
CLD
(Mid-Level minion.)
(3,463 Views)
