Installing DAQmx 9.1.1 with LabView 8.2, but DAQ-related libraries don't appear
I noticed you had other modules installed. Are you able to access other modules like your NI-IMAQ VI's?
Rohama K.
Message 11 of 20
(1,535 Views)
Yes, I can access the NI-IMAQ VI's.
Message 12 of 20
(1,529 Views)
I need a few screenshots from you. Go to Control Panel> Add and Remove Programs> National Instruments. Once the National Instruments Software Window opens, select NI-DAQmx ADE Support and then click on Modify. Expand everything and attach screenshots of what is there.
Thanks!
Rohama K.
Message 13 of 20
(1,517 Views)
Also, attach the contents in the Installation Logs folder:
C:\Documents and Settings\All Users\Application Data\National Instruments\Installation Logs
Rohama K.
Message 14 of 20
(1,515 Views)
Here are the files you asked for.
Message 15 of 20
(1,505 Views)
Hi Maryam,
It looks like DAQmx 9.4 was not uninstalled completely. I will need you to try the following:
1. Uninstall DAQmx 9.1.1.
2. Reinstall DAQmx 9.4 using the Command Window. The directions are below.
1. Open up a Command Line Window
2. Type: cd <Path to the folder that has DAQmx 9.1.1 Setup executable>
*Note: There is a space between cd and the file path.
3. Press Enter. You should see the path change.
4. Type: Setup.exe /reinstall /log reinstallLogFile.txt
*Note: There is a space after Setup.exe, /reinstall and /log.
5. Press Enter. This should run the reinstall for DAQmx and create a log file in the same folder as Setup.exe called reinstallLogFlie.
3. Uninstall DAQmx 9.4
4. Reinstall DAQmx 9.1.1 using the Command Window. See directions above.
5. Open LabVIEW and see if the DAQmx VIs are there. If not, attach the installation log files that were created by the reinstall and MAX Technical Report.
Rohama K.
Message 16 of 20
(1,485 Views)
In step 2, do you mean "Type: cd <Path to the folder that has DAQmx 9.4 Setup executable> "?
Message 17 of 20
(1,477 Views)
In case you meant "install NIDAQmx 9.4" in step 2: the downloaded installer file is named "NIDAQ94of5.exe". Do I have to run this file before I can get the appropriate "Setup.exe" file?
Message 18 of 20
(1,473 Views)
Accepted by topic author MaryamAli
Sorry for the confusion. The executable you are talking about should create a folder that has a Setup.exe in it after running it. For the first reinstall,it should be for DAQmx 9.4. The second reinstall should be for DAQmx 9.1.1. Let me know if the directions are still unclear.
Rohama K.
Message 19 of 20
(1,469 Views)
Thanks for your help! The DAQ-related files have installed correctly.
Message 20 of 20
(1,446 Views)
