Installing LV 8.21
Should I uninstall all components LabView 8.20 before install LV 8.21 ?
(3,637 Views)
wojtek,
The answer is... that depends.  Check out this KnowledgeBase article about upgrading:
LabVIEW 8.2.x Upgrade Issues
Stephen Meserve
(3,626 Views)
 Hmmm so, I think that uninstall old version and install new after will be better.
 Thanks for reply
(3,609 Views)
I would recommend uninstalling LabVIEW 8.2 before installing 8.2.1. Though upgrading from LabVIEW 8.2 to version 8.2.1 is generally not a problem, there is a known issue where performing this upgrade without uninstalling can cause some linear algebra functions to operate incorrectly.
I hope this helps!
Casey Weltzin
(3,572 Views)
I am going to do that.
Thanks for reply.
Regards
(3,551 Views)
