Installing LV 8 steps on LV 6.1?
After instaqlling LV8 on my machine yesterday, I discovered this AM that the FP VI's have been deleted from
...\LabVIEW 6.1\vi.lib\FieldPoint
DId anyone else run into this issue?
Has anyone else managed to get LV8 installed while maintaining their LV 6.1 applications that use FP?
Not a happy camper,
Ben
(4,631 Views)
I installed the evaluation version of 8.0 which came with FP 5.0 (although I don't remember whether it installed the FP VIs) and it definitely didn't remove my 7.0 VIs. I don't know about 6.1, as I usually don't need to open it, but I can check (although not at the moment). In any case, I haven't uninstalled it yet.
Did it do this only to 6.1?
___________________
Try to take over the world!
(4,621 Views)
Thanks tst!
At this point I am still not sure which way to go from here.
If I believe what I was told by support I have to abandon my customers that are trapped back in LV 6.1 OR buy a new PC because the two version can not get along.
Ben
(4,613 Views)
I have talked to support about this and it appears I have to choose between LV 6.1 FP VI's and LV 8.
I will post more when I can say more.
Other ideas that do not involve abandoning the LV 6.1 FP VI's would be very welcome.
Ben
(4,600 Views)
I checked it, and I would like to make a very important correction.
I do not have FP 5.0 installed. What came with the LV 8 installer was MAX 4. I downloaded FP 5.0 separately, but had not installed it yet. Since you say it will remove my 6.1 FP VIs, I will probably wait until I really get 8.0 (or 8.01, or 8.1....).
Thanks for being the guinea pig. Smiley Sad You get some stars for that.
___________________
(4,591 Views)
Hi tst,
I think you called it with FP 5.
I will update this this thread in the end with what finally ended up working or not working.
Ben
(4,575 Views)
This is my final update for this thread. Please see this thread
http://forums.ni.com/ni/board/message?board.id=110&message.id=3905#M3905
for more information on this problem.
Bottom Line:
LV 6.1 VI's that use FieldPoint can not exist on the same machine with LV 8 because LV 8 use FP 5.
You will have to choose between LV 6.1 FP and LV 8.
Hopefully this will save others some trouble.
Ben
(4,562 Views)
