Installing LabVIEW Run-Time Engine 8.5.1
I want to run saved VI's from one computer with LabVIEW 8.5 Professional Development (8.5) on another computer using the Run-Time Software.
After installing LabVIEW Run-Time Engine 8.5 (LabVIEW85RuntimeEngineFull.exe from http://joule.ni.com/nidu/cds/view/p/id/861/lang/en), do I need to do anything else before running a saved VI created in LabVIEW 8.5 from another computer? I install the program, but the only options under programs-national instruments are:
-data socket
-License Manager
When I installed LabVIEW DSC Run-Time System 7.1 on the same computer there was an shortcut under "programs-national instruments-" to LabVIEW DSC Run-Time System 7.1, which is what I need but for the Run-Time Engine 8.5 instead.
(12,915 Views)
I believe you can not do this. The runtime I believe requires the executable version of the VI.
You will need to build an application from your saved VI. In the application builder, you can include the run-time libraries and progras. This will help ease the installation process. Once you have completed this operation, you can just run the executable with your VI.
(12,911 Views)
Joseph is correct. The run-time engine is only for "stand-alone" executables created with the Application Builder (included in the Professional version or higher, or can be purchased separately if you have the Base package). To run a vi in the development environment, you need one of the LabView packages.
Message Edited by Edjsch on 05-12-2008 01:48 PM
(12,898 Views)
