Installing Linux Runtime
I need to install a Linux LV7.1 app on a machine that has damnsmalllinux v1.5 already installed on it.  I'd like to install the 7.1 runtime, but it is an rpm, which this knoppix-debian based distro does not support.  Are instructions for a manual install of the runtime available?
(6,211 Views)
hello,
you could try to convert the packages from rpm to deb with alien.
use the option "-c" to convert also the installscripts.
regards,
robert h
national instruments
(6,199 Views)
Thank you Robert. You put me on the right trail. I made some changes before following along however.
After a brief search last night I found the supported linux versions page, which referenced 2.6 as required, and also found the application builder guide which mentioned X11. damnsmalllinux is 2.4, and does not use X11. So I decided that change was in order before going further, and switched to SLAX. This gives me 2.6 and X, while still allowing me to run off a small compact flash drive (no rotating media allowed for this app). I'll happily try any other distro recommended that fits, but for now I am on SLAX.
Back on the trail: Starting with labview-rte-aal-1.0-1.i386.rpm and labview71-rte-7.1-1.i386.rpm I converted the rpms to tgzs (rpm2tgz), which I then changed into mo's (tgz2mo), which were in turn loaded using uselivemod. Quite a few files showed up in /usr/local/lib/LabVIEW-7.1 & usr/local/share/natinst, so it looked like it worked.
I then tried to run my executable and got the error message
"Can't find LabVIEW runtime library liblvrt.so.7.1
Make sure this library is installed in your LD_LIBRARY_PATH
search path, or in /usr/lib"
I looked for liblvrt.so.7.1 and found it in /usr/local/lib/LabVIEW-7.1
I copied it to /usr/lib, then running the executable netted
"Can't load LabVIEW runtime library /usr/lib/
libLVMesaGL.so.3: cannot open shared object"
Looking back in /usr/local/lib/LabVIEW-7.1 I noticed that libLVMesaGL.so.3 was in there too. I tried
echo $LD_LIBRARY_PATH
nothing there, so I then deleted the file from /usr/bin and tried LD_LIBRARY_PATH=/usr/local/lib/LabVIEW-7.1
Now running the executable nets me
I checked to make sure that liblvrt.so.7.1 is still in /usr/local/lib/LabVIEW-7.1, it is.
In summary, the files appear to be out there, but I cannot seem to point at them correctly. Any thoughts?
(6,187 Views)
Did anyone ever solve this?  Having the same problems in 8.2.1.
(5,900 Views)
If the executeable is a shell script I would put "echo $LD_LIBRARY_PATH" somewhere near the top, just to see what is going on.
--Patrick
(5,894 Views)
Just got it working.  It seems to ignore the usual dynamic linker stuff (LD_LIBRARY_PATH, ldconfig etc) and look in a hardcoded list of random places, including /usr/local/lv60 (despite this being Labview 8.2 not 6.0....)
The solution for me was to put a symlink into /usr/lib pointing to the RTE:
ln -s /usr/local/lib/LabVIEW-8.2/liblvrt.so.8.2.1 /usr/lib/liblvrt.so.8.2
Also, make sure that the libGL.so.1 and libGL.so.1.2 links in /usr/lib point to the one that comes in /usr/local/lib/LabVIEW/patchlib rather than the one that comes with the OS (this gets rid of the OSMesa messages, as described in the readme in the patchlib directory).
And suddenly it worked 🙂
(5,890 Views)
Oh, and you need to copy /usr/local/natinst/LabVIEW-8.2/patchlib/libOSMesa.4 into /usr/lib too.
(5,886 Views)
