Installing MAX
Hi guys, I downloaded the evaluation version of Labview 8.5 from the NI website, but did not find MAX on it, can anybody please guide me where and how can I install MAX on my pc.
thanks
(4,142 Views)
hi
have you installed the package or not.
If you install it , by default it max will also be installed ......
any one in the forum please Correct me if I am wrong...
(4,136 Views)
hi
Yes I have installed the self extracting package on my pc but max was not installed....any solution ?
thanks
(4,133 Views)
MAX is not installed with just LabVIEW. MAX is only installed with the installation of hardware drivers. If you want to use DAQmx, NI-GPIB, etc., then download what you want and then MAX will be automatically installed.
(4,129 Views)
Hi!
   Dennis is right, MAX is not distributed with LabView.  Instead, you'll find max bundled into the driver CDs accompaining NI Hardware, for example, I got my FieldPoint Hardware with FieldPoint drivers CD, which includes MAX.
   If you want the complete set of Drivers, here's your link (suitable for LV 8.5).  The only problem is that you can't download separately the three CDs, as was reportered in another post.
   Hope it helps!
graziano
(4,124 Views)
Hi guys.
thanks for the above needed DAQmx...will download from the link and try it. If any problem will come back to you all...thanks again
(4,118 Views)
