Installing NI DAQmc BAse on Linux
I am trying to install the proper driver for the USB-6501. I used the iso file from the link below.
http://www.ni.com/download/ni-daqmx-base-3.7/4269/en/
My system said that the install was successful, however when i go to open up one of the applications (such as Driver Wizard or NI I/O Trace) I get an error message. It says "failed to execute child process "usr/local/bin/niiotrace" (no such file or directory)). But I go to that directory and I see it is there. Is there something else that I need to install or did I do something wrong during the install process?
I am currently running redhat 6.6 with kernel 2.6.32-504.el6.x86_64.
(3,499 Views)
I would assume that the installation might be corrupted. Have tried reinstalling? Also, is that driver supported on your OS?
(3,403 Views)
I have reinstalled twice already with the same result. This is a driver compatible with Redhat 6.6.
I believe I am missing some packages. I have continued to search online for some answers and came across the following link. Hopefully that will solve the issue.
http://digital.ni.com/public.nsf/allkb/93C92D41B25341B286257A4D007BACB8
(3,375 Views)
