Installing NI-DAQmx 9.7.0 Application Development Support
I am currently trying to install Labview 2009 (my former copy was lost when my former computer's motherboard overheated). The installation has gone fine, I think, and I am able to create new projects etc.
When I downloaded NI-DAQmx 9.7 (the full installer), I seem to be unable to install several pieces of software - please see the error-file attached. I am not worried about the NI I/O Trace 3.0.2, NI MAX 5.4, or NI Network Browser 5.4.0, as I believe the higher editions I have are backwards-compatible.
With the NI-DAQmx 9.7.0 Application Development Support however, I cannot install this due to incompatible products. Do you know what kind of products this error is referring to? I am at a loss, as I also do not know what the symbol shown in screenshot means (I've accessed this window through trying a custom installation, but I cannot change to a tick/cross).
Thank you in advance!
Carl
(3,534 Views)
Hi Carl,
Is it possible you are able to post your MAX System Information, so we can see in depth if there are any conflicts on your system. DAQmx 9.7.0 is supported by LabVIEW 2009, so I am unsure of what the exact issue is at this time.
In NI-MAX, if you could: Right click on My System >> Create Report >> Select My System, and select Simple Report. Generate the report, then please upload it so I can see.
Best Wishes,
James Kent
James Kent | Applications Engineer | National Instruments UK & Ireland
w: uk.ni.com | ireland.ni.com
(3,487 Views)
Accepted by topic author cdavies203
Hi James,
Thanks for responding. I have managed to fix the error: I found that the NI-VISA version installed on my computer was version 5.4, which is incompatible with LabView 2009. As soon as I uninstalled this, and instead added version 5.3, I was able to install DAQmx ADE without a problem.
Thanks once again!
Carl
(3,476 Views)
