Installing NI-DAQmx Base using a LabVIEW built installer
I am using a PDA, LabVIEW Mobile Module and the CF-6004 to perform instrument control and data acquistion for a handheld instrument I am developing. Because this instrument is going to be used by another party outside my organization, I am also supplying support software for a companion PC. The support software includes ActiveSync to connect the PC and the PDA, a LabVIEW built application for viewing the data collected by the handheld instrument, a LabVIEW built application for installing/updating the LabVIEW (Mobile Module) built PDA applications and NI-DAQmx Base to install the drivers on the PDA. Ni-DAQmx Base needs to be included because if the PDA battery runs down completely, programs/drivers I installed are lost and the other party needs to have the ability to reinstall the necessary files on the PDA.
The problem is that I cannot find a way to include NI-DAQmx Base in the installer I build to install my LabVIEW built applications onto the PC. It is not listed under the Additional Installers catagory of the installer properties. I cannot run the NI-DAQmx Base Setup.exe with the "Run executable at end of installation" option because I cannot have two LabVIEW installers running simultaneously.
Right now my work around is to use a batch file to install each component sequentially.
Is there anyway to include my my LabVIEW built executables, the Run-Time Engine and NI-DAQmx Base in the same installer package?
DAJone
(3,423 Views)
Hello, It is necessary to install Daqmx Base on the machine connected to the PDA and then use the Utility to install it on the PDA. See page 4 of the Mobile Module Manual:
https://www.ni.com/docs/en-US/bundle/371296f/resource/371296f.pdf
(3,394 Views)
