Installing an USB driver
Hei,
My goal is to establish USB bulk communication between an USBdevice and Labview. I have been following this procedure: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1qzCAA&l=en-US and used NI-VIsa Driver Wizard.
Everything went fine till I  have to create cat file. This I have to do  because my OS is 8 and in oder to get "allowance" to install the drivers I need to have it digitally signed. Appereantly it should be at location:
C:\Program Files (x86)\Windows Kits\8.0\bin\x86
But I can't  find the in2cat exe nowwhere. I reinstalled the the windows kit where the inf2cat appereatly is couple of times. So,
How do I get to inf2cat?
Is there any other "cosy "way to establish USB communication?
Any recommendations or advices are also appreciate.
thanks for the help
(4,665 Views)
What sort of USB device is it? It's almost always a mistake to try and use the wizard unless you have full information on the protocol used. Is it a design of yours?
(4,651 Views)
It is just a simple microcontroller that ia already programed and the only way to acces it, is through usb. Also everything is provided VID-PID, endpoints with pipes, command syntax... to establish the protocol. Other protocols I2C and SPI are not document. So, that's why I thought to use NI-VISA driver wizard 🙂
(4,634 Views)
Accepted by topic author D_1
Does it work if you try to disable the "Safe Drivers" setting in 8?
http://www.makeuseof.com/tag/how-can-i-install-hardware-with-unsigned-drivers-in-windows-8/
Best Regards,
T Simon
Certified LabVIEW Developer - Certified TestStand Architect
(4,578 Views)
Simon, thanks a ton. You are a life saver 🙂
(4,540 Views)
