Installing labview with DAQmx
I am trying to install labview 2009 on a new computer with windows xp but am having some problems. I installed labview and the f3 patch.Everytime i try to install Ni-Daqmx 9.1 I get an error saying that
The system cannot read from the specified device
This happens when it tries to install support for  labview 1.13.0. Any suggestions on how to rectify this would be helpful
Priam
(3,379 Views)
There is no LabVIEW 1.13.0, so I have no idea where you are seeing this. It's possible you have a corrupt download.
(3,370 Views)
I tried redownloading and installing and keep getting the same error? I have attached a picture of it.
(3,355 Views)
Hi Prima,
Where are you installing this driver from a DVD or a folder? I suggest that you download it from here and run it on your machine from a folder on your desktop. It might be a corrupted download or a bad Disc/Drive if you are using a Media. You might want to try to copy the disk to your desktop and trun it from there as well.
Thanks and have a great day.
Esmail Hamdan | Applications Engineering | National Instruments
(3,324 Views)
