Instance of template cannot find IMAQ VISION VI's, if called by an executable
Hallo community,
I have a nasty problem and I tried a lot but cannot get rid of it. It's not the more common problem with the path names as reported frequently in this forum. If the template is called by the executable (on my machine with the development system)  it will be found as if called from the development environment. But in the first case it shows a broken arrow because it cannot find a lot of  subVi's which are defined in the library nivision.llb. It worked fine some time before but then I reorganized a little and deleted some files in the path where the template is situated (eg. nivision.llb, which is still in system32). Since then this error comes, even if I give back nivision to that path. How is it possible, that the same template called by the development environment seeks its subVi's in other places as if called by the executable. Where are these information stored and how can it be changed again?
I cannot continue with my project, so I would greatly appreciate some help.
Detlef
Message 1 of 1
(2,302 Views)
