Instrument Driver (66319B)
Hi all,
i need assistance on locating an instrument driver for model no:   66319B , Power supply unit from Agilent Technologies.
Currently using labview 8.0.
Thank you.
(4,254 Views)
Here it is
Lots of drivers can be found on the instrument driver network on the NI site
Dave
(4,249 Views)
Hi Dave,
from this link: http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E9445659CE034080020E74861 , it doesn't state if it do support labview 8.0 though...
Thank you
(4,246 Views)
True, but it does say that it is compatible with 7.1, 8.20, 8.5 and 8.6. So my guess is that it will be fine with 8.0 too.
I had a cursory glance at the llb's for 7.1 and 8.5 and they look the same.
Dave
Message Edited by DavidU on 10-20-2008 09:13 AM
(4,236 Views)
Hello!
Sadly it doesn't support labview 8.0 when i tried to install the driver i download from the above link.
Is there a way i can still get the instrument driver that supports labview 8.0?
Best regards
(4,214 Views)
Exactly why do you think that the driver is not supported with LabVIEW 8? Installing the 7.1 version should allow it to be opened and saved. Do you get an error message or something else when you try to open it?
Since it's an IVI driver, you can also create a 8.0 version directly. Look at the link here about the instrument driver import wizard. All of the available LabVIEW drivers for this instrument have used this wizard to create them. Download just the CVI driver to do this.
(4,208 Views)
