Instrument Driver for Fisher Science Traceable Manometer
 I am looking for the Instrument Driver for Fisher Science Traceable Manometer. The manometer has RS232 port and currently only provides GUI software with 8045 Data Acquisition System:  https://traceable.com/catalog/product/view/id/3396/s/8045/category/51/
  I will appreciate if you can help me on how to use Labview to control the existing GUI or have already developed the driver for this instrument.
Herman
(4,023 Views)
This company doesn't document the output format / protocol for the RS232  ...  but have you asked them for that information?
Reverse engineering a rs232 protocol to read values usually isn't that hard, but ask first .. saves time 😉
there was a time where portmon from MS could be used to do it....  but I think it's not possible anymore with the more recent OS ....
A close look on the web page give:
so 9600 baud, even parity, 8 data bits, 1 stop bit  seems to be a good start value 😄
Greetings from Germany
Henrik
LV since v3.1
(3,982 Views)
Herman, I am looking for the same driver. Did you ever find a solution?
Russ
Herman
(3,785 Views)
I created one as attached. I found it does not require "write command" on writing.
(3,780 Views)
Thanks!
(3,773 Views)
