Instrument Driver v5.1 on LabView 8.6
Hi all,
I just downloaded instrument driver for Keithley 6221, but the problem is that it was developed in LabView 5.1 and cannot be used in LabView 8.6. So what I need is older version of LabView to convert it to newer versions, I guess. Question is where I can find any older version of LabView to download or is any other method to use it in 8.6?
Thank you  for your answers.
(3,764 Views)
You cannot "find older versions of LabVIEW to download". At least not legally. Just post the driver here and someone can resave it in a version that you will be able to open in 8.6.
(3,752 Views)
Thanks for reply, so here is the driver. Could somebody save it in 8.6 version?
Radas
(3,729 Views)
Attached is in 8.2. I think it's an IVI driver. Whoever wrote the code had, for some stupid reason, the DLL installed on the F: drive. The DLL wasn't in the archive.
(3,712 Views)
