Instrument I/O Assistant installation incomplete...Student Edition 7.1
I'm using LabVIEW 7.1 Student Edition, and I can't seem to get the Instrument I/O Assistant to work. The student edition doesn't come with the Drivers CD, so I got the I/O Asst from ni.com. After reading some other posts I uninstalled the I/O Asst from the Add/Remove programs, then reinstalled, but it still didn't work.
Am I running into the limited functionality of the student edition?
(2,516 Views)
The Instrument I/O Assistant vis are only installed from the Driver CD, within the Driver CD, you will see a separate installer for the Instrument I/O Assistant(iioa), run the installer from there.
For more details, check the KnowledgeBelow:
http://digital.ni.com/public.nsf/websearch/AA99FA8704D5E22686256D6A004464ED?OpenDocument
(2,504 Views)
