Instrument I/O Assistant not properly installed
I recently purchased a student edition of Labview 2009 and I've been having problems with the intrument I/O Assitant. Each time I place it on the block diagram I get the error message that it was not properly installed. I've searched the knowledge bases and carried out the recommended remedies to no avail. I downloaded drivers from NI.com, uninstalled NI VISA and reinstalled the its latest version still nothing worked. Can someone please help me out here.
(2,173 Views)
I see that you uninstalled and reinstalled the drivers, but did you make sure to only reinstall the Instrument Assistant after the drivers? Also, what operating system and driver versions are you using?
-Zach
(2,156 Views)
