Instrument I/O assistant error msg "Unable to view proterties"
Hi, NI's AE,
  I have re-installed many times NI LabView8.2(EV) + DAQmx8.3 on all
  in one SOC platform(X86) with WinXP(SP3) step by step, but all
  rebooting fail after DAQmx8.3 installed.
  Then I re-install pure WinXP(SP3) + LabView8.2(EV) + DAQmx8.9,
  rebooting ok.
  LabView simulated VI from template works well, however I got error
  "Unable to view properties" when I drag & drop "DAQ Assistant"?
  After google the related issue of "Instrument I/O Assistant error".
  I check the "Add/Remove S/W List" and "System Services" of window,
  everything seems ok.
  Attach file description :
    Add_Remove_List.jpg -
        No extra software installed, except NI's S/W.
    Add_Remove_NI_List.jpg -
    The key drivers, NI Instrument I/O Assistant & NI-VISA 4.0 &
        NI-488.2.2.46 all be installed well.
    NI Service List.jpg -
        NI's related service be well active.
    Instrument IO Assistant - Unableto view properties error.JPG -
        Drag & drop "DAQ Assistant" VI, popup error dialog box
        "Unable to view properties", not "Create New Express Task"
        form.
  Is there any compatible issue between LabView8.2 & DAQmx8.9 ?
B/R
Hank
(4,429 Views)
(4,427 Views)
And the error message file!
(4,426 Views)
