Instrument IO Assistant can't find in Lower Version LabVIEW
Does  Instrument IO Assistant only use with Latest LabVIEW?
I install both LabVIEW 2011 SP1 and LabVIEW 2012 SP1,but i can't find  Instrument IO Assistant in LabVIEW 2011 SP1.
Is there any way possible to use Instrument IO Assistant in both Version of LabVIEW?
CLA & CLED
(2,841 Views)
No, the assistant was available as far back as 8.0 I think.
(2,829 Views)
Have you installed the Device Driver DVD including NI-VISA drivers after installing LabVIEW?
(2,825 Views)
Yes, I installed the Latest 2013.02 Device Driver DVD, from here : http://joule.ni.com/nidu/cds/view/p/id/3802/lang/zhs
I CAN use Instrument IO Assistant in LabVIEW 2012 SP1 normally, but I can't find it in LabVIEW 2011 SP1.
My primary development environment is LabVIEW 2011 SP1, it is inconvenient.
CLA & CLED
(2,811 Views)
Accepted by topic author lhb5883
I install the LabVIEW 2013 with Device Driver 2013.08, it seem that I could use Instrument IO Asisitant in Both LabVIEW 2013 and 2012SP1, But Still can't found in LabVIEW 2011 SP1.
I guess maybe there is something changed since Device Driver 2012.08.
I hope it maybe a bit help for other people.
CLA & CLED
(2,745 Views)
