Instrument assistant
Hi I'm trying to run Instrument Assistant in LabView 8.2 and whenever I put it on the block diagram I get the error "Measurement & Automation Explorer or the Instrument I/O Assistant is not installed correctly. Please install these from the LabView Driver CD." I've installed the specific driver I need from the NI website but I am still getting this error.  Any help would be appreciated!
(2,677 Views)
Try repairing the MAX from add or remove programs,
(2,673 Views)
Hi jlc5540,
What version of NI-VISA are you using?  Also, what type of instrument are you trying to connect to, and what sort of interface are you using to communicate with it?  Thanks!
Taylor G.
Product Support Engineer
www.ni.com/support
(2,649 Views)
