Instrument driver for TDS430A
I cannot find an Instrument Driver for the TDS 430A digitizing oscilloscope. Can anyone direct me to one or, if not, suggest a similar instrument whose driver should work reasonably well. For example, I see that there are drivers for the TDS 420 and TDS 460.
John
(3,005 Views)
I'm pretty sure that the only difference between the different models is the sampling rate. There is a single driver for the 420 and 460 If you need to make any modifications, it would probably be just to the horizontal config function.
(2,991 Views)
