Instrument driver for agilent 8960 to run CDMA tests
Hi, just wonder if there is an instrument driver for agilent 8960 to run CDMA tests? I know 8960 has E1963 and E1968 driver, but 1963 is designed for W-CDMA and 1968 is for GSM/GPRS/EGPRS. So is there a driver designed for CDMA mode? Thanks a lot!
(2,652 Views)
Accepted by topic author dangzhe
Unfortunately, it does not appear that there currently is one.  When I search the Instrument Driver Network I only find the two drivers that you pointed out.
Brandon Treece
(2,635 Views)
