Instrument handle through a shift register generates error code "-1073807346"
Jeff,
Thanks for the suggestion.  I checked the VI hierarchy and all of the API references point to the LV 2011 version.
I am unable to post the code due to security issues.
Message 11 of 15
(844 Views)
Then please log a call with NI and share your code with them.
If its a bug we need to know about it.
Take care,
Ben
Message 12 of 15
(841 Views)
Ben,
I put together a similar vi using the config file palette. It worked fine in LV 8.6. It did not work in LV2010. I currently don't have a machine with LV 2009 installed to test it there. I have attached the test code I tried. Is this a bug or a fundamental change in LV?
Message 13 of 15
(819 Views)
UNder 2010 SP1 it works OK from a caller invoking Init read close.
Just openeing th FP and invoking one at a time it fails as expected (see my early post on the VI going idle).
SO look fine to me.
Ben
Message 14 of 15
(810 Views)
@NNS-CAO wrote:
Ben,
The Config file API was completely revised between 8.6 and 2009.  They do NOT work with each other
I kind of would like a break on the referance wire if 8.6 and 2009 apis are interchanged but know this is not possible-  You are not the first to find this expected operation  feature the hard way.
Message 15 of 15
(806 Views)
