Instrument not appearing in VISA Resource
I have a GPIB resource.  It is showing up in MAX, but not in resource name constant.  I checked I/O filtering and refreshed the resource name, but the problem persist.  What's happening?  See attached picture.
Kudos and Accepted as Solution are welcome!
(3,376 Views)
Try the Select VISA class menu item just above I/O filtering in the right click menu.
(3,363 Views)
I tried that.  The resource still appear in MAX, but no in a resource name constant of my LabVIEW.
(3,350 Views)
There is a good resouce on the NI website that describes how to handle the exact situation you seem to be encountering. You can get to that page by following this link:
http://digital.ni.com/public.nsf/allkb/61BA81FB87962275862574FA006F4815
Hope This Helps,
Doug B
(3,337 Views)
Accepted by topic author jyang72211
I tried some of those approachs, but they are not what I am looking for.  It seems like even though the resource does not show up on labview, and I am still able to talk to it if I key in the resource name manually.  The USB-GPIB instruments are the ones that gave me problems, since I would know the primiary address of the instruments but not their interface ID. They are using different controllers.
I wrote a vi that loop through interface id 0-4 with a specified primary address to issue the *IDN? command and check for response.  Through this method, I am able to find the address string of the GPIB and talk to the instruments even visa can't find that resource.
I hope that this method will hold up through time.
(3,319 Views)
