Instrument reports: Input buffer overrun (Error -363)
Hi all,
I am currently trying to control an Ametek XG 12-240 DC power supply using LabVIEW 2013. I have downloaded all of the drivers from Ametek and can communicate with the device using NI MAX. When I run the "ametek simple example.vi" to set a current and voltage level and turn on the power output, I get
"Error -363 occurred at Ametek XG Power Supply.lvlib:Error Query.vi
Possible reason(s):
Instrument reports:
Input buffer overrun;"
I am new to LabVIEW and have not found any online solution to the problem. Any suggestions?
(4,438 Views)
That's an IVI driver written by Ametek/Sorensen with a custom error code created by them. If you have CVI, you could perhaps debug the driver yourself. Otherwise, you might want to contact the vendor. Running I/O Trace would give you an idea of what commands are being sent.
The last time I used one of their IVI drivers, ki had problems as well. Instead of doing any debug, I just spent a couple of hours writing a LabVIEW driver. A power supply is a simple instrument.
(4,417 Views)
