Instument I%2FO %22not installed correctly%22.
I'm trying to inport data from a scale through a serial port using the Instrument I/O VI.  I get the message " Measurement and Automation Explorer or Instrumenent I/O
Assistant is not installed correctly. Install these from the LabView driver CD".
 I have tried reinstalling All of Labview and I can't seem to find the specific files for MAX or Instument Assistant on the disk to install them individually.  I have tried to download older versions because I'm running LabView 8.2 Student from 2006, I'm not sure which version I need to make this work.
Alternatively is there any other way to get serial data into my program?
Any help would be amazing.
JoMu
(2,661 Views)
Do you have NI-VISA installed? It is separate from LabVIEW.
(2,659 Views)
I'm not sure but my guess is no. I have something called Visa Interactive Controll and the VISA help functions but I'm not sure Visa is on there. If it is I think it needs to be reinstalled but I don't know which version I need to be compatible with the lab view I'm running.
(2,655 Views)
If you installed NI-VISA, then you have MAX on your desktop. You can determine the version in that. Personally, I would never use the assistant. There are a couple of serial examples that come with LabVIEW. Just do a search for ' serial'.
(2,644 Views)
