Insufficient on-board memory available to perform the acquisition
i have the code attached. I want to increase the number of samples that can be measured in a single run from 30000 (what i think is the memory of the device) to whatever (like 100000 or more). The number of samples can be specified by the control accumulate.
i found that fetching can help but dont know how to implement such thing, or if you know other solution.
many thanks in advance.
(579 Views)
Well you only have so much memory on the device.
So you will need to shorten the record length when using higher sample rates
=== Engineer Ambiguously ===
(567 Views)
But that is exactly the problem i'm trying to solve. people proposed fetching as far as I understood, but no idea how to use it.
(552 Views)
