Intalling DSC RT doesn't put Historical Data in MAX
When I install the 8.6 DSC runtime it doesn't put the "Historical Data" in MAX.  This is just a common xp build with labview 8.6 on it.
(2,816 Views)
DSC Distribution Application Does Not Show Historical Trend Data
Is this the problem you are having? Go ahead and try this solution and let us know how it works out
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
(2,802 Views)
Unfortunately  this is not the same issue.  I actually don't even see the label Historical Data.
(2,788 Views)
It sounds like there might be something wrong with your Citadel database.  I would recommend either trying to reinstall Citadel or trying to reattach the existing database.  You might try to reinstall DSC and see if you unchecked Citadel or MAX support.  Please let me know if you have any problems!
Hope this helps
Mathan
Message Edited by mathan on 10-29-2008 07:14 AM
(2,784 Views)
