Integer number to binary labview
Hi all
Would like to know how to  to convert the output Integer to binary .
(11,099 Views)
There's a Integer to Boolean Array function, is that what you're after?
/Y
Qestit Systems
Certified-LabVIEW-Developer
(11,095 Views)
there is a standard function called "Number to Boolean Array" in the Numeric -> Conversion palette.
is that what you were looking for?
NOTE: the num to bool array conversion, does not work on arrays, you would need to put that in an autoindexing loop.
EDIT:
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(11,095 Views)
Thanks for your fast response. I don't need Boolean because I will send this binary data to FPGA.
(11,079 Views)
Accepted by topic author Sattam
i guess you have to be more transparent what you want to accomplish.
your data is binary already, all you see is a representation of that.
(11,076 Views)
Just pass the integer directly to your FPGA then.  After all, an integer is nothing but a series of bits interpreted in a specific manner.
(11,055 Views)
(11,045 Views)
