Integer to an array of byte
I want to convert a short non signed integer like 3 to an array of bytes like
11000000 and to show this array in the indicator.
I am affraid it is a really basic question but... I am a new user.
Thank you.
Fred
User of http://www.foorum.com/. The best tools for usenet searching.
(2,838 Views)
The program attached below should do the trick. It converts the number to a boolean array which is then converted to 0 and 1.
I hope this helps,
Erik van Dijk
(2,838 Views)
Go to boolean palette, use "number to boolean array" and the "boolean to 0,1". You'll get an array of 0's and 1's.
Good luck
(2,838 Views)
