Integral X (t) vi
Hi,  I am using Labview 8.2 and I am trying to integrate a
60 Hz sine wave coming from a AC power source ( via DAQ).
My question is how do you set the value of dt within the integral x(t) vi?
Whenever I set this value (lets say 0.016) and run the vi
continously it automatically sets back to zero.
PJ
(3,291 Views)
I don't understand what you are doing. There is nothing that should be run continuously and you simply pass the value of dt to the integral function.
(3,283 Views)
It also makes no sense to use 0.016 as dt. dt is the sampling interval, not the period of the waveform. I suppose one should ask: do you know what an integration of a waveform is? It's basically the area under a curve. There are various numerical methods to implement this on a computer, with the trapezoidal rule being one of the simplest.
Also, integrating a sine wave just gives you a cosine wave - i.e. a phase shift. More specifically, it's -cos(x) + C, where C is some constant. That's just simple mathematics.
(3,272 Views)
