Integral blocks from labview 7.1 where is in labview 2010
Hi I must integrate sampled signal. In labview 7.1 is good checked blocks for it. But where is equivalent in labview 2010?? I cant find it.
Message 1 of 8
(3,272 Views)
http://zone.ni.com/reference/en-XX/help/371361G-01/gmath/integral_xt/
Did you try the search capability for the functions palette?
Message 2 of 8
(3,267 Views)
Ok. Thank you. I used this function now but I get empty array on output. My table are filled by the signs NaN. I would like get as I show in annex.
Message 3 of 8
(3,256 Views)
Please upload your VI along with saved data, or if you're reading the data from a file then please upload your file.
Message 4 of 8
(3,249 Views)
Accepted by topic author limatorek
This is my VI, that i have now
Message 5 of 8
(3,232 Views)
Hi limatorek,
The problem is that the first element in the array you are trying to integrate it "NaN," or "Not a Number."  Having this number in your array is causing the integral to always be NaN.
I believe that the the first element is becoming NaN because you are subtracting 4 from your array index prior to the array having 4 elements in it.  You are basically going out of the range of the array (trying to acess the -4 element) and this is causing the average function to result in NaN.
Hope this helps!
Chris V
Message 6 of 8
(3,212 Views)
Chris thank you very much. You are rigth. Now everythink is ok.
Greating from Poland.
Limatorek
Message 7 of 8
(3,197 Views)
Please mark Chris' response as the solution, rather than your message. You can unmark a solution using the Options menu right above the message to the right.
Message 8 of 8
(3,182 Views)
